1 - 17 of 17 Posts
are there any springs from another car that will work in a 71 ascona wagon? we have one here and the prev. owner cut the front springs to lower it. trying to find something that will fit. i did some poking around on the internet and came up with miata springs as getting pretty darn close in measurements. anybody have any inputs?
Are you just looking for something different? :confused: There are probaby several members that have extra sets and I'll bet they'll be cheaper than buying Miata springs.
JM2CW,
Harold
springs
i do not know if they will work but you might try a chevette , also i have a set for a 74 wagon if you need them just pm me
Discussion Starter #7
well, we were looking to replace the cut springs with a progressive miata lowering spring as they can be had for about 40$ a set
Simon;
Most of us have stripped a few cars and have several sets of both front and rear Manta/Ascona springs. What we're asking is, do you WANT to go with the Miata springs, or go back original? I have several sets of Manta/Ascona front/rear springs myself.
the reason he is asking is he wants lowered units not stock
we want to replace the cut springs with a real engineered lowered units not return to stock..fyi this is my son .....lol he is trying to come up with a lower cost solution for aftemarket lowered springs for ascona...we like the lowered look looking for springs that will give same look but better ride than cut springs.....:yup:
Simon;
Just checked with Coil Spring Specialties about
twirling up some coils for the wagon.
Gulp....
Front - 2 inch drop, 275lb spring rate
Rear - 2 inch drop, 170lb spring rate
$544.80
(Yeow!)
I think my ride height is quite satisfactory
thank you.
Gulp....
$544.80
(Yeow!)
It's only money! :sigh:
I recently purchased some springs for the front of a little truck that I'm working on. They aren't cheap. Now I have to try to find a spring for the rear of my little dump truck. I'll probably have close to $400 total in mine. Definitely not what I had planned on doing when I purchased the truck.
RB is selling gussets for the lower control arms. Heck you might want to see what his price is for doing up a set for you. He uses a different ball joint that drops the front 7/8". Cut the rear springs and you may be happy with that and come out cheaper. :dunno:
Harold
7/8's might work. I just went from 60 series tires to
50 series. Good news - it's a half inch lower. bad news-
it looks a half inch higher. 7/8's would put it back to
stock looking. And get new ball joints in the bargain
if I'm readin' right. RB is who?
Thanks,
Don.
Gulp....
$544.80
(Yeow!)
thank you.
Ouch! Yea, that's ridiculous. I remember when they cost $125 per pair....so that's $250 per set. Guess they are charging a bit more these days.
Oh yeah, RB, Duh.
With California roads the way they
are these days it's probably a pretty
good idea to look into said modification.
It looks pretty herky, (herky-tough, strong,
up to the task.) And keep a little clearance
underneath is not a bad idea either.
Thanks,
Don.
1 - 17 of 17 Posts
