I started my GT the other day to simply let it idle for awhile. (I do this at least once a month during the winter.) When I started it this time, the starter would not disengage from the flywheel after starting. Man, it was making a racket to say the least! :shocked:
I figured the starter was hung up so I tapped it with a small hammer. No luck. The I tapped on the ignition switch on the steering column and starter disengaged. Now the engine is running fine. Soooo, I shut it off to try it again. Same thing happened except this time, I tried to stopped the engine by taking the key out but it kept raising hell with the engine running and no key! I really started to freak out now so I tapped on the ignition switch a few times and finally it stopped. This all leads me to think that the ignition switch is screwed.
Any thoughts? I guess I'll be contacting Opel GT Source tomorrow!
