Last week I fired up the engine for the first time....no oil pressure...I had packed the gears with white grease while assembling so it should have pressure immediately....nothing....I tried priming using a stripped down old distributor...I could not get anything...I installed a new oil filter.... I removed the oil pressure (old style) check valve and installed the later style pump cover from Gil...nothing....(I did remove all the parts from the old check valve) So I decided it "had" to be the pickup tube.......I jacked up the motor....took the crossmember out and dropped the pan...I thought that the gasket might have been bad so I made a real strong gasket...and that had to seal...I had checked the tube and it did not leak...no cracks or anything....so I put it all together...thinking the gasket must have been sucking air....so I put er all to together and late this afternoon I tried again.... nope...zero...nada
What else is there ? I am sure the oil pump gears are spinning...my drill motor only goes clockwise (it's old)...the crankcase is full... even if the oil gauge or the sending unit was bad I would still see oil at the rockers...nope..
I am at a total loss.....HELP !!!
