OK I have done too much thinking on this project. And my thoughts were scattered in one post with a title that didnt quite fit. So here is all the info I have on doing a ManZuki or such Suzuki Opel mating.
Anyway, the reasons for this are simple. Parts are cheap, it adds HP (100 HP is goal), Gas Mileage (Targeting 30 MPG), and lightens the car improving handling.. or at least thats the idea.
You can bolt any of these to the Geo Tracker or Samuari Tranny. Also will need to use a tracker/Samurai oil pan. FOr more info:
http://www.ado13.com/dohczuke/dohc.htm
The three motors I am looking at are:
94 Suzuki Swift GT - Twin cam, 16 valve, Port Fuel Injected, 4 clyinder, 1.3L motor.
Specs: 100 HP @ 6500, 83 Ft/lb @5000 - MPG 29/36
88 Chevy Sprint - a 1.0L 3cly, single cam, intercooled turbo.
Specs: 70 HP, 107 ft/lb - MPG 37/43
95 Geo Tracker - 1.6L SOHC
Specs: 95 HP @ 6000, 99 ft/lb @ 3000 - MPG 25
Apparently a intake manifold exists that can hold a weber 32/36 downdraft and eliminate the EFI.
Looking at weights..
The GTs Curb weight is : 2105
The Mantas Curb weight is : 2232
94' Swift is: 1951 lbs
88' Sprint is: 1620 lbs
95' Geo Tracker : 2339 lbs
The Opel 1.9L wieghs about 275 (according to Bob), the tranny wieghs 75 (Shipped a few). That's 350 lbs. Add alternator, manifolds, etc.. we are looking at about 400 lbs. For the drivetrain.. according to teamswift.net consensous there is the entire 1.6L DOHC drivetrain with accessories wieghs in at around 250 lbs. Lets call it 275 due to the Samuaris tranny. We save 125 lbs of the front of the Manta/GT, bringing our weight close to that of the Swift. Heck and the swift had A/C, etc.. so that can be added to the engine.
Assuming 2250 lbs for a Manta and 56% front weight bias (1260 lbs), reducing the engine weight by 150 lbs (to 1110 lbs) will drop the total weight to 2100, and change the front bias to about 52%. Should make for a nice handling car I'd think. Thats based on teh 1.6L DOHC, the 1.0L Turbo is probably a bit lighter.
Now gearing.. How much are the larger gears in the Samuari going to affect 0-60? Better or worse?
The trannys ratios:
'74 Opel Manta - 3.428 / 2.156 / 1.366 / 1.00 (Edited per Bobs Post)
'94 FWD Tranny in the Swift are 3.41/1.89/1.28/.914/.757
'88 Samuari RWD Tranny 3.65/1.94/1.42/1.0/.795
'95 Geo Tracker 3.65/1.95/1.38/1.0/.86
Can handle the power of the dual cam 1.3B better.
Performance:
There are headers and computer chips available for the Suzuki motor. Also you can use Nissan throttle bodies, they bolt on. So supposedly it's VERY easy to get over 125 HP from it and about 100 ft/lbs of torque from this little dynomo.. with only bolt on mods. Which in our GTs and Mantas should be real fun especially since they will be lighter anyway.
The final drive gear is 4.10 on the Sprint and Swift. (3.44 for most Mantas)
94' Swift
Tires 175/70r14 (2% taller)
MPG : 29 city / 36 highway
0-30 MPH - 2.6 Secs
0-40 MPH - 4.5 Secs
0-50 MPH - 6.3 Secs
0-60 MPH - 8.3 Secs
0-70 MPH - 11.5 Secs
0-80 MPH - 14.6 Secs
1/4 Mile time - 16.6 @ 84.7mph
95' Geo Tracker:
Tires: 195/75R15 ( 14.5% Taller )
MPG: 25
o-60 in 7.1 sec.
1/4 mile - 1.40 @ 98 mph
Not bad... and a better judge of what the Manta or GT can do since its transmission is the one I will use.
One more thing to note for anyone thinking of this conversion:
The 1.6L DOHC, Suzuki Motor with a turbo setup, can get close to 200 HP and 200 ft/lbs of torque and quite streetable. Apparently most the big power is high up in the RPM range (6000-8000), but with all the mods the HP and torque at the lower 2000-4000 is markedly improved over stock as well. Supposedly with the turbo setup, and cam, etc... gas mileage in mixed driving is still in the 30 MPG range !!
Without Turbo, they get like 150/140... Thats a lot of HP form that little damn motor. again stays in the 30+ range for mileage.
Also there are claims a 1.0L 3cly. Turbo (Stock gets 37 city / 43 hwy), with the right mods gets into the 105 HP and 125 fl/lb range with only a minor amount of work. He said he has a Sprint that dynoed 100 / 115 at the wheels and still got 30+ city, and 40+ highway on premium.. !!!!
So there it is.. I think a good base for anyone thinking of doing a Suzuki conversion.. Now anyone able to do the math? What could I expect the Mantas preformance to be if I don't modify the engines in any way..
How does that compare to the current gearing.. ?
The trannys ratios:
Performance:
94' Swift
0-30 MPH - 2.6 Secs
0-40 MPH - 4.5 Secs
0-50 MPH - 6.3 Secs
0-60 MPH - 8.3 Secs
95' Geo Tracker:
MPG: 25
o-60 in 7.1 sec.
