1 - 4 of 4 Posts
i have the front and rear bars from addco and i can't seem to keep the drivers side swaybar bushing in place. every few days it pops out and its just sitting on the bar, but not in the mount. any ideas? will post pic in a a bit.
Discussion Starter · #2 ·
heres pics.
First of all I would get rid of the rubber and switch to poly. That will make the bar about 20% more effective and may stop the bushing from popping out. Your other solution is to just put a hose clamp on the side that is poping out. That should get rid of the problem.
I can't even get the rear (Addco) bar on.....it doesn't seem to fit without hitting the body over the torque tube/differntial area. On the front one I do have the poly bushings and never a problem. You might want to try changing them.
1 - 4 of 4 Posts
