41 - 59 of 59 Posts
Wondering if a posi( lsd) was available In the 68 kadett? Noticed my car dug two little ruts in the alley instead of just one when I took off aggressively.
Yes, there was a ZF 004 series LSD as an option, but those are rare today and sought after by the historic racing guys. The Kadett B and GT had its own type of LSD because of the C-clip axles so the common type ZF 004 LSD can't be used, there is no possibility to insert the clips.
I can't add anything but can reminisce about those days. I had a '67 Kadette L and a '69 Kadette LS, the 67 with my son in the picture, (now 52) had a sowing machine (lol) for a engine (54HP) and on the highway would get 41 or so MPG on 30 cents a gallon regular. The '69 LS had a 1.1 with the two one barrels. Don't mean to mess up the thread but the flashback got the best of me.
Your Noble Friend ;-)
Sorry if I just can't keep my mouth shut when I see something like that. You didn't have any Kadette. Never did. You might have had a Kadett.
To the general public: Is it really that complicated? If it is a complicated word and you don't know how to spell it, look it up for Christ's sake!
(End of morning rant)
Dieter
Opel Key Master
Young Olds, my question would be what year do you have? How about some pictures for once. You state you have a front light, and adjustable seats. But only a 70 model would have been equipped with those. A 68 had reflectors, and non adjustable seats.
Discussion Starter #45 (Edited)
It has reflector, not side marker lights. I was told it is a 68 and the registration shows it has been registered as a 68 as far back as 79. No locking column which was required starting in 69. It does have reclining seats and appears to be all original. I will try to get decent pictures after work today.
424671
Here is one picture for now.
Opel Key Master
Okay, the seats are interesting, and this is not the first time I have seen this. In most cases 66-69 seats did not have an adjuster on the side, and the whole seat lifted forward. There was an LS on Facebook, I don’t think this is it, but it also had the adjusters on the seats like that and looked like they were off of a GT. This may have been only available on the LS model. But this is only the second example I have seen like this. I will do some parts book searches for some info. Also you have the rare trim on the rear surrounding the license plate. I have this trim NOS but it was only available for a 68 LS
Discussion Starter #49
These seats unlatch and lift/tilt forward as the stocks ones in my manta did as well as recline. Do you mean the molding that spans between the tail lights?
In Europe the aluminium trim between the taillights was only available in the Olympia A, not in the Kadett B, and it was copied from the Commodore A that got a similar trim a year earlier when it was introduced.
Discussion Starter #52
Makes sense since this car is technically an Olympia a. I wonder why they badges then as kadett in the us?
Discussion Starter #54
I’m glad, I like the Olympia better. Not that I’d refuse a stripped down kadett b.
Discussion Starter #55
Finally getting around to doing a tune up, hoses etc. for timing I recall something about a dimple on the flywheel and the pointer tab being lined up( that is where it is set now at idle). Also I recall always seeing people suggest not bothering with the solex, I have my idle at approx. 800rpm but the idle mixture screw wants to be about 1/8-1/4 turn from seated to run it’s best. Also looking for point and plug gap.
Discussion Starter #56 (Edited)
Found ignition tune up specs. What is the timing at when you line up the marks?
Discussion Starter #58
Jeez, ok. I have not worked on a cih for a couple years now. I thought lined up meant your ignition was 5* advanced or something like that.
Only 1975 Opels were 5 degrees BTDC.
41 - 59 of 59 Posts
