21 - 22 of 22 Posts
Hey Adam
I was looking at your wiring and noticed that you were running two fans.
Would you elaborate more..size,amp,cfm and how they worked out?
Discussion Starter · #22 ·
I currently have only one fan on the car. That wiring diagram was done when I had a second fan mounted to an ac heat exchanger that was sitting horizontally in the nose. Now with the new smaller second coolant heat exchanger and the oil cooler in the nose the second fan is not installed.
The one fan I have is zip tied to the front of the core support. It was taken from a junk yard. I did not pull it so I do not know what it is from. It works really well and my whole cooling package keeps the temp gauge right at half all of the time.
Diameter: 15"
Direction: Push
Fuse: 30 amp
21 - 22 of 22 Posts
