I've made mention of a certain Ascona 'wanna-be' rallycar, affectionately known as the Turd, in these forums before. It currently has a nearly stock front suspension, deviating only by means of a fast ratio rack and pinion, 380 lb. springs, Bilstein shocks, a softened-up front swaybar, and polyurethane bushings. This suspension has worked well for road use, playing on dirt roads, and for rallycross use. But the car's eventual intended use for high speed rallying will require a better, stronger suspension system.
The front crossmember has been significantly strengthened by the addition of about 80 steel gussets. And since they were all cut out by hand and I chose to TIG weld them all in place to reduce warpage, there are probably around 30 hours into the crossmember alone.
