I decided to swap out my 160 degree thermostat for a 180 degree today. When I went to put everything back together, I noticed that the thermostat housing bolt hole closest to the engine valve cover is "slightly" stripped. I say "slightly" because it can be snugged up to where it cannot be moved by hand but not tight enough to keep a tiny bit of coolant from weeping out around the gasket at that end of the housing when the engine is running. The other side is fine BTW and can be tightened down nicely. Is using a heli-coil or perma-coil to renew the bolt hole the best solution or is there some other way of fixing this problem?
Thanks,
Matt
P.S. I know several folks I could call with this question but believe it or not a search turned up nothing! So, I thought I would start a thread for future reference - surely someone else has had this problem and will again...
Thanks,
Matt
