I just received a GT gas pedal to experiment with, so that I can try to decrease how quickly my GT's solid linkage opens the throttle on my single side draft carb set up. I'm about ready to try to rebend it or go nuclear with a chop off and weld on something that will decrease how much the linkage moves, but before I do that, the thought occurs to me that there are two, possibly 3, adjustment points in the GT solid linkage set up: The threaded rod at the gas pedal, the other holes in the gas pedal, and the rod along the firewall.
The thought occurs to me: Why does the rod along the firewall have adjustment potential?
I can understand the fine tuning potential of the threaded rod when, say, switching from the Solex to a Weber or when adjusting the height and range of throw of the gas pedal, but the one along the firewall seems to be screwed all the way together on every GT I can remember. Opel worked out the length needed for the other rods that aren't adjustable, why is the firewall rod not also a set length?
Okay, now let's consider the current set up on my car. I'm using a single side draft carb on a Midikit manifold with the new chromed throttle linkage that recently became available, plus a special length linkage rod made just for the SSD set up that goes from the passenger side pivot to the carb. The special rod for the SSD has an added feature that the normal length rod that the chromed linkage set comes with does not: It's also adjustable.
So, why have I started this thread? Well, the linkage opens the throttle on the carb WAY too quickly. Unmodified, the first 1/2" of gas pedal movement(at the pedal rubber) would have you at 60mph in no time. There was no fine feathering of the enhanced throttle response of the side draft. Totally annoying when limping along in traffic. So I drilled a hole in the gas pedal lever, where the threaded rod mounts, 3/4" closer to the gas pedal's pivot and this improved things greatly. Now I can push the pedal a whole inch before I'm at full throttle! Yes, I'm exaggerating.
But I want even more feather to my throttle response. Double what I currently have would be perfect. So, this has me thinking about modding a pedal and other things. Now, they sell this linkage and special rod for guys with SSD's, right? I ask Do all those guys also have touchy gas pedals? Do they have to keep one foot on the brake to dampen the sudden acceleration? Wouldn't it have been smart for the linkage rod maker's to make the various levers on the linkage longer or shorter as needed to soften the throttle response? Or make them adjustable?
There's that adjust word again. Thinking about how the rate of movement changes depending on where in their rotation arc the levers are at, I'm drawn to why that firewall rod is adjustable again. What is it that I, personally, want? Well, almost all the acceleration and speed occurs during, say, the first 1/4 of the throttle opening(personal observation), after that it's mostly all watching your speedo slowly go over 100mph. I don't go there. Mostly I drive around at 35-40mph average speed. I want my fine speed adjustment during that first 1/4 of the throttle opening and then after that I don't give a fig.
So, here's a question: Has anyone messed around with various adjustment positions of the solid linkage and what sorts of different behavior have you discovered?
I'm going to go play with my gas pedal and take some pics and make some drawings of my linkage so that I can try to find an adjustment method that will lead me to throttle response heaven.
Talk about any related subject you want......
