Ok,
I replaced both grommets on the passenger and driverside firewall, so the throttle linkage is in good shape. When I go to install the Weber 32/36 the throttle linkage rod is jammed against the passenger side grommet. Its so tight the linkage is frozen. :sigh: The old solex had lots of play in the linkage rod, you have to pull the rod forward to mount it on the ball nut. Not so with the weber, the throttle shaft that holds the ball nut on the weber looks to extend about a 1/2 inch further out then the Weber. The only way to install linkage rod is with the weber off the intake.
I ordered all parts from Opel GT source so the linkage bracket and ball nut are correct. If I shorten the throttle linkage rod by about 1/2 inch it would work; but I should not have to do this. Something is screwed up. Is it something with the motor mounts or transmission mount?
Thanks for all help
Thanks for all help
