1 - 6 of 6 Posts
I pulled my turn signals today in preparation of my new lenses being here Thursday. Does anybody have any tips to help remove the clips inside. I figure some dental tools or something similar, but I figured I would ask. I don't want to brake any posts. Thanks
424780
RunOpel
I used a fine point needle nose pliers and was just very careful. Did you order the Fog/Driving/Turn signal lights from OGTS? If so, you will really like them. They come with tech notes and easy to install.
Discussion Starter #3
I thought about the fog lights. I love fog lights, for some reason. Haha
I spent way to much money at OGTS, so I only got the clear lenses.
They come with new clips, so I was thinking about trying to cut them off.
RunOpel
If the fine point needle nose pliers don't work, then try a fine point pick and pry the tabs back. I used a pick along with the pliers and it worked without breaking a tab. I know the feeling about over spending at OGTS, its very easy to do :) :)
1000 Post Club
I gently used a cutting wheel on a Dremel or 90 degree small wire cutter and carefully cut one side off which releases the tension on the clip. You can then just peel them back. No damage to the posts
I would cut them off to avoid breaking the posts.
1 - 6 of 6 Posts
