1 - 4 of 4 Posts
· Member
Hi All,
I thought I'd just throw this out here to see if this is something I should be concerned with.
I was putting my cylinder head back onto the block this morning. And in the process of cleaning the top of the block, I noticed that pistons 1-3 look about the same on their tops. A layer of carbon had deposited there. But on piston #4, the top is shiny. I scraped off as much of the deposits from all the piston tops as I could. The first 3 pistons were dry, like dust. But the last piston was like oily dirt.
Since I had the head redone, I hope this will fix whatever caused #4 to be different. Anyways, I thought I'd just see what you all think.
Thanks and Happy New Year,
Manny
PS. What do you use to torque the last head bolt on the driver side closest to the firewall? It's a pain to get to.
Manny, was the combustion chamber on #4 clean like the top of the piston? If so, you may have had the beginning of a coolant leak in that cylinder/head and you've been steam cleaning it while driving. Hopefully the rebuild has cured the problem.
· Member
Hi Ron,
I didn't pay attention to the combustion chambers when I took the head to Roger Wilson. But a coolant leak would explain why my cooling system was being pressurized and blowing my bottom radiator hose off.
But the top of the #4 piston was not clean. It was covered with oily deposits.
Manny
· Old Opeler
AntiFreeze
The oily deposits will have come from the antifreeze in the cooling water - if coolant had been getting into the cylinder.
Check the old head gasket - if you still have it - for signs of "blow-by" and leakage.
I am pretty sure that any Opel head rebuilder would have checked the casting for cracks before expending any effort on it so carefully check the cylinder block for cracks or leaks too.
Carefully check the head/block faces for flatness as well.
Use a top quality Felpro "Printo-seal" head gasket and make sure that none of the head bolts either bottom out in the threaed holes (if your head or block have been surfaced) or have "dozy" threads ( ie stripped threads )
1 - 4 of 4 Posts
