1 - 2 of 2 Posts
Opelnut
Does some one have the "FACTORY" torque specs for the 6 bolts that attach the Transmission bell housing to the Motor?
Also the two brackets that tie the bell housing to the block.
(1 bolt on the side engine block, 1 bolt by the pan, and the two bolts that thread into the bell housing)
and I suppose while I am at it the bolts that hold the dust cover to the bell housing ?
Thanks:veryhappy
tomking
Thanks:veryhappy
36 ft lbf.for the bell housing. The others that are 13mm heads should be 15 ft lbf.
1 - 2 of 2 Posts
