Thom71GT said:
1) Im guessing you can go and buy new plugs pretty easily. Where did you get them?
Not neccessary the only one you will need are the headlights, they are included in the packet you got.
Things like wiper motors, etc.. you can either do like I did and that is just use female lugs and wire it that way one wire at a time.
YOu will notice all the male/femal plug sizes through out the Opel are no different than the ones you can get at the electrical dept at Home Depo. So just go get a bunch of male and female lugs from them before you start.
Thom71GT said:
2) How did you cover all those guages and switches in the dash? Obviously the ez wire kit will not be specific to all those things, but what do you do? Make splices? Im confused on that one.
Simple, the dash lights are powered by the parking light circuit. The oil sending wire connects to the oil pressure guage.
The basic directions cover wiring the basic ammeter.
Simply put you will have wires to feed the different circuits as labeled in the EZ harness. That feeds either the power or the ground signal to the gauge.
There should be one gauge power feed required and that will come from the EZ harness. All the grounds can go to ANY ground. I built a ground block with a big ground wire to the body, with a bunch of terminals to hook up all the loose grounds.
Refer to the Manta directions to see how I did the Manta, the GT is similar, it seems more complex just looking at it, but the principal is the same.
Thom71GT said:
3) My tumblers went out in my ignition years ago so I have a push button under the dash. How to I do the rewire to include that? Or, should I snag a different steering column that has a good ignition switch and key? I have one available.
Actally this makes it easier. You know exactly where to wire the ignition power to.. Instead of the column you will terminate it at the push button.
Thom71GT said:
4) I have the one plug S-10 upgraded alternator. Not understanding where the wires go on that one when I look at the Destec Wiring Diagram. How do I rewire that?
Its a simple circuit and in the universal directions. Look under GM page 11 I believe.
Thom71GT said:
5) Finally, anyone that has done this before. What are some tips and warnings?!?!?
Yes, on the Manta though. Yes it is intimidating at first, but in reality it ends up being quite simple.
Rule #1 - READ THE DIRECTIONS - ALL OF THEM
Rule #2 - DON'T CUT wires within the circuits. Unless you have done a complete trace and understand exactly what you are cutting and why.
Rule #3 - THESE Directions:
http://www.goindesign.com/ebay/EZ20manual.pdf
Rule #4 - DON'T get intimidated.. its much easier that it seems at first
Rule #5 - Preplan the project.. seperate and go through the rewiring in your head with the diagrams, instructions and harness before you start. The more familiar you are with the harness before you start the easier it will be.
Rule #6 - READ THE DIRECTIONS - ALL OF THEM
Rule #7 - FOLLOW THE DIRECTIONS now that you read them twice.
