1 - 3 of 3 Posts
opel assimilated
transmission
hellofa weekend with the gt, fought with the electronic ignition.(never got it to work) installed lower front spring(worked great) and lost alot of tranny fluid(again).. my question is this, earlier this year, my tranny fluid just started pouring out of the area between the bell housing and the actual tranny body. Of course i heated up the 3&4 syncro, so I got another tranny, new front seal, and installed it. it worked and felt great for 500 miles or so. Now all of a sudden, its started just pourin out of the same place again. Any Ideas? I even put lots of honda bond on the seal before I put it in. ARRGGHHH!!!
Off hand, I'd say that the bottom 2 bolts that hold the trans to the bellhousing are loose. There's also a gasket that is for the trans-to-bellhousing mating area.
1 - 3 of 3 Posts
