Tranny and diffy lube checks and fill
Hi Everyone, Maglin, you will need to get under the car, for the tranny on a GT there is a plug on the side, it easy to reach, as I recall it is a hex plug, take it out, and stick your finger in, if you get oil on your finger, it is full, if if flows out, it is overfull.
Same thing for the rear end, but I cannot remember what the rear end plug is, a hex or a square drive to get the plug out.
As for the rear seal, that is easy to change, and last I heard you can get those seals easily enough. If you have a problem with the torque tube, be sure the mounts are good, else you will have that problem again.
Paul
