transmission seals...
Using a dye grinder I ground off the mushroom edge on the outside of passenger side transmission linkage (where shaft is pressed in) in order to take the linkage piece off and get to the seal on that side. I ground it down flush with the linkage piece and still can't get the piece loose from the shaft. Do I have to go inside the depression at the end of the shaft to grind some off around the edge of the opening?? I'm kinda stuck.......and don't want to get TOO carried away with the grinder without having a new plan of attack.
Any help appreciated.
