Ok, I'm not sure which way to go with this symptom:
1) I have poor/weak throttle response below 2500 rpm, but above that it really breaths great up to 6000+ (I havn't gone above 6k yet) But it will hesitate usually when I'm shifting unless I keep the RPMs high. Especially going into 3rd for some reason.
2) Also, when I adjust my mixture screws, I know they should be roughly 2-3 turns out, ballpark, but it seems like I go as much as 4 turns out....is this ok?
(Or could this be from a vacum leak?? I have the carbs off and I'm replacing the softmount gaskets to try and fix.)
Setup:
2.2l top/bottom, good but not a real wild cam.
Choke - 34
Mains - 145
Air Cor. - 180
Emuls - F2
Idle - 55F9
Pump - 40
Thanks for any pointers...
~kyle
Setup:
Choke - 34
Mains - 145
Air Cor. - 180
Emuls - F2
Idle - 55F9
Pump - 40
~kyle
