1 - 1 of 1 Posts
I have two custom-made steel racing wheels, 13” x 7”, in 4 x 100 mm bolt pattern. They are race wheels therefore they have a 45-degree lug nut taper. I may have some of the lug nuts in 12 x 1.5 pitch as well. Normal 60 degree lug nuts cannot be used.
These had tires mounted on them but never saw any use. They were test fitted to the rear of a Kadett but never run.
Backspace is 4.75”. Holes were drilled in the face of the rim edges for tire screws (for drag race use). It does not affect tire sealing. Wheels weigh about 16-1/2 lbs each.
They are located in southern New Hampshire, but I travel to CT frequently so I could possibly deliver anywhere in between. Would prefer not to ship.
Asking $50 for the pair.
430178
430179
430180
430181
1 - 1 of 1 Posts
