Order Update
Gordy:
There are others that can answer that question better than I can as I am building an engine now and haven't used the S-10 clutch yet. But there is a lot of info available on this site. The clutch surface is larger and can handle much more torque. Also, depending on the manufacturer of the clutch pressure plate you may need to grind the inside of the bellhousing in one spot. Again, a lot of info about this by doing searches.
For those who involved in the recent group buy:
The order has been placed. They will begin manufacturing immediately and the rings gears are readily available. Therefore, I may see them as early as the first week in February.
If there is anyone who didn't contact me but may want one, there may be one or two available. However, they will not have the holes drilled for the pressure plate. This was done in case someone wanted to use a different clutch set-up. The flywheel can be taken to your machine shop with the pressure plate for drilling and tapping. PM me if you're interested.
Special thanks to Mark aka Manta Rallier for his special assistance with this group buy. If it were not for him we would still be trying to drum up orders.
John
Gordy:
John
