41 - 60 of 203 Posts
Vendor
Did this die off? Seems like it would be a good time of year to consider having these made up again.
Todd K.
No
Gary said:
So can the step in the flywheel be removed and the stock clutch disc and pressure plate used?
If you remove the step and try to use the stock clutch, you'll never be able to disengage the clutch (relieve enough pressure on the pressure plate to release the disk). That's also why it's so important to grind the flywheel step the same amount that you grind the flywheel clutch disk surface, else you'll end up with a constantly slipping clutch . . . even with a brand new disk!
I have purchased 2 aluminum flywheels from the manufacture here in California. I believe them to be similar to the Unorthodox wheel. They are drilled for the S-10 pressure plate. I believe there are a few left on the last production run. They cost $400.00. They don't sell to the public but I can use my resale license to buy you one. If your interested let me know.
Thanks for your help!
I will get in touch if this group buy doesn't restart.
Hiro
Pathologic Opeler
what about a clutch?
is the Al flywheel ready for the opel clutch or can it be faced to accept the chevy s-10?
oops..this question was answered in prior post
I talked to the guys at Unorthodoxracing. They will build me a flywheel. The only problem is they will not do a set up and make less than 6 of them. Looks like I will have 5 to sell. Who wants one? What you guys don't want goes to E Bay:ugh:
