Alrighty folks as always i wait until we are a month out from Carlisle before tackling problems on the old White Mistress. Last year i picked up a LE-Jetronic system. Apparently this system was on this car before and it was swapped out to a carb and then i bought it. I believe i have the wiring all figured out as well as the fuel lines. What i need help on is the coolant lines.
I have a thermostat housing that has 3 large connections. I "believe" the left goes to the water pump, the middle goes to the lower radiator and the right one goes to the upper radiator. Am i correct in this? Also does anyone have a part numbers of hoses that would fit? The part stores around us don't really have stuff hanging around like they used to,
On my next small issue. I ordered the adapter for the coolant drainage in the rear of the block. OGTS sent the large fitting and i assume the EURO motors had a much bigger hole. From reading a few past post i found the plug i removed is a m14-1.5 and i need to adapt this hole to a 5/8 hose. This correct?
For those that are familiar with the old setup on this car feel free to chime in on things you remember. Also any pictures people have of an LE system installed would help. Many of the old pics and links on this site no longer work. Tomorrow I am going to start disassembly of the motor and coolant lines to start the retro fit install. I pray i can get it all in and running by may 1st. That will give me 12 days to test drive and work out any bugs before our 700mile trip.
Any help is very appreciated.
Chad
Chad
