I moved this thread to the "1B - Ignition System" Forum, as vacuum lines relate to distributor advance, which is ignition.
But if you're after info on the PCV lines (the hoses from the valve cover to the intake manifold and to the carb intake), have a search around the "Engine Mechanical" Forum.
