I'm planning to install 246mm vented front brakes from a 1985 Rekord E. Calipers are made by either ATE or Delco (I've not got them yet) and have one 52mm piston each. I've heard that installing these to a GT isn't very hard task but I don't know if the stock master cylinder works fine with these.
Stock total front brake piston area is about 64cm^2 and with these it would be only 43cm^2. Or is it even possible to compare these numbers because 2-piston calipers are fixed and others floating?
If someone here has done similar upgrade please tell what problems I'm going to encounter.
