1 - 6 of 6 Posts
Arguably the toughest challenge I've had in a while was trying to fit vented front brakes into stock multi-hole Opel steel wheels. They are so damn restrictive that even standard 1975 Opel brakes do not fit within these wheels. This was my solution.....
Discussion Starter · #2 ·
Here's the bracketry welded in place. The calipers are Wilwood Dynalite's with four 1.375" pistons. This is only slightly more piston area than stock Opel 2-piston calipers, so it works well with the stock master cylinder. If larger pistons were used, the pedal effort would be easier, but it would have excessive travel.
Bob,
Awesome work as usual, I stand amazed at what you are able to come up with!
Two quick questions:
1) what was the source of the vented disks?
2) The hub looks like it has been beaten fairly well. Is there a story behind it?
Darrin
The rotors are standard 4-cylinder Vauxhaul Carlton/Opel Omega rotors. They bolt right to the stock hubs. Although in this instance, I have spaced the rotors with a custom 1/4" spacers in order to gain additional clearance. They are the same diameter as 1975 brakes (246 mm). I can't recall the thickness, but I think they're 25 mm.
The hubs are just old hubs....typical New England rust/corrosion actually.
Vented discs for 13" wheels
Beautiful work Bob. This ties right in to my Manta brakes thread from the other night.
The 246mm discs I have are 21mm thick.
How much do you figure it cost you in parts to do that? (realizing that you did alot of fabrication yourself..)
I didn't buy the rotors...I have no idea what they cost. The rotor/hub spacers were about $55 each, the calipers $120 each, brake pads about $55, caliper brackets $11 each, hardware another $16. Brake lines and fittings cost $52.
1 - 6 of 6 Posts
