At freeway speeds I notice vibration (not major but noticable) that seems to come and go. I have new tires and balance, and just had an alignment from a reputable and knowledgable shop. The steering gear is adjusted properly (just checked) and so are the wheel bearings.
What would the symptoms be if the drive shaft were not balanced.....or could the rubber bushing in the torque tube cause this problem if it is worn or dried out....??
at times its rock steady and at times the whole car seems to have a vibration.
