next installment of weekend probs. I tried unsuccessfully to install a crane ignition system. its hooked up properly, but there is not enough juice to fire the spark plugs. without the system pluged in, i get 12v at the coil. with the system plugged in, i get about 5v. HMMM, im stumped. when trying to crank it over, there is not even enough juice to make a timing light flicker on the coil wire. once again, Any ideas? could i have a wiring problem from the ignition to the coil? Argghh!!!
