1 - 4 of 4 Posts
Here are a few numbers from a list complied (or at least revised) by nobody:
WAGNER PD31 [ThermoQuiet Pads] Front
WAGNER SH1001-5 [Shim] Frt.
WAGNER R100762 [Brake Master Cylinder] Reman.; 20.64mm Bore; w/Vac. Boost
WAGNER F100780 [Brake Hose] Frt.
WAGNER F100779 [Brake Hose] Rr.
WAGNER F98430 [Disc Align Kit] Frt.; (Incl. Front); (Incl. Axle); Sequential Series
WAGNER F98430S Carded Substitite for F98430
WAGNER F109543 [Hold-Down Kit] Rr.
WAGNER F109543S Carded Substitite for F109543
WAGNER F98323 [Bottom Cup] Rr.; Pri.
WAGNER F98323S Carded Substitite for F98323
WAGNER F34948 [Pin/Anchor] Rr.
WAGNER F34948S Carded Substitite for F34948
WAGNER F6477 [C-Washer/Clip] Rr.
WAGNER F6477S Carded Substitite for F6477
WAGNER F6477S [C-Washer/Clip] Rr.
Here is the complete brake list:
BRAKE LINING/FRICTION, FRONT
AUTOSPECIALTY 25-031-01 [Brake Pad Front]
AUTOSPECIALTY 23-031-02 [H.D. Pad Front]
BENDIX D31 [Disc Pad Pkg Front]
BENDIX D31IQ [Disc Pad Pkg Front]
CARLSON 736-D31 [Brake Pad] Frt. Axle
BECK/ARNLEY 082-0407 [PREMIUM BRAKE PADS] PREMIUM BRAKE PADS; Front;
BECK/ARNLEY 087-0407 [SEMI-METALLIC BRAKE PADS] SEMI-METALLIC BRAKE PADS;
BECK/ARNLEY 088-0407D [AXXIS DELUXE BRK PADS] AXXIS DELUXE BRK PADS; Front; IOE
BECK/ARNLEY 088-0407M [AXXIS MTL MSTR BRK PDS] AXXIS MTL MSTR BRK PDS; Front
BECK/ARNLEY 088-407SD [AXXIS DELUXE BRK PADS] AXXIS DELUXE BRK PADS; Front; IOE
BECK/ARNLEY 088-407SM [AXXIS MTL MSTR BRK PDS] AXXIS MTL MSTR BRK PDS; Front;
BRAKE LINING/FRICTION, REAR
AUTOSPECIALTY 30-350-11 [Brake Shoe Rear] (curved lever)
AUTOSPECIALTY 30-424-11 [Brake Shoe Rear] (straight lever);230 x 50
BECK/ARNLEY 081-0606 [REMAN BRAKE SHOES] Rear; Brake shoes with levers & folded ends.
BENDIX R424L [Relined Brake Shoe Set Rear] 9 1/16 x 1 31/32
CARLSON 350 [Brake Shoe] Rear; 230 x 50
BRAKE PAD SHIMS
AUTOSPECIALTY SH-1214 [Disc Pad Shim Kit Front]
BENDIX SH31 [Shim Kit Front]
CARLSON 18003 [Pad Shim Kit] Disc; Axle; Front
BECK/ARNLEY 084-1058 [FIBER BRAKE PAD SHIM] Front; Fiber shim
BECK/ARNLEY 084-2013 [STEEL BRAKE PAD SHIM] Front; Steel shim
BRAKE DISCS/ROTORS
AUTOSPECIALTY EBR-043 [Rotor Front] 8.0
AUTOSPECIALTY EBR-043L [Power Stop Rotor Front] 8.0
AUTOSPECIALTY EBR-043R [Power Stop Rotor Front] 8.0
BRAKE DRUM
AUTOSPECIALTY EBD-037 [Drum Rear] 231.0
BRAKE CALIPER, LOADED
A1 CARDONE 17-342 [Loaded Caliper] Reman.; Front; Right; OE Metal Piston
A1 CARDONE 17-343 [Loaded Caliper] Reman.; Front; Left; OE Metal Piston
AUTO CALIPER EXCHANGE, IN 3382 [Brake Caliper] Reman.; R.H.; Loaded
AUTO CALIPER EXCHANGE, IN 3383 [Brake Caliper] Reman.; L.H.; Loaded
AUTOSPECIALTY 40-13003 [Loaded Caliper] RH; Prem.; Frt.; 45mm Cyl. Bore Size
AUTOSPECIALTY 40-13004 [Loaded Caliper] LH; Prem.; Frt.; 45mm Cyl. Bore Size
BRAKE CALIPER KIT
AUTOSPECIALTY KC-13001 [Caliper Kit Front] 48mm
BENDIX 66733 [Repair Kit Front]
BRAKE CALIPER BOLT/PIN
CARLSON 14006 [Guide Pin] Disc; Front
BRAKE MASTER CYLINDER
A1 CARDONE 11-1541 [Master Cylinder] Reman.
BECK/ARNLEY 072-0623 [Brake Master Cylinder]
CROWN 11-1541 [Master Cylinder] Reman.; Disc
BRAKE MASTER CYLINDER KIT
BECK/ARNLEY 071-2539 [Brake Master Cylinder Kit] Major repair kit w/piston
BENDIX 22523 [Repair Kit]
BRAKE, WHEEL CYLINDER
AUTOSPECIALTY W-13000 [Wheel Cylinder Rear] 15mm
WAGNER F100685 [Wheel Cylinder] Rr.; 5/8" Bore
BRAKE CALIPER BLEEDER SCREW
CARLSON H9411 [Bleeder Screw] Disc; Front
BENDIX H94014DP [Brake Bleeder Screw] Disc; Front
BRAKE HOSE, FRONT
AUTOSPECIALTY HB-13003 [Hose Front]
BRAKE HOSE, REAR
AUTOSPECIALTY HB-13302 [Hose Rear]
BRAKE DISC HARDWARE KIT
AUTOSPECIALTY HK-902 [Disc Hardware Kit Front]
BRAKE ANTI RATTLE SPRING
WAGNER F98430 [Retainer/Anti-Rattle Clip] Frt.; (Incl. Axle)
BRAKE PIN KIT
BENDIX H5053 N/A
BRAKE COMBINATION KIT (AXLE)
AUTOSPECIALTY HK-508 200mm
AUTOSPECIALTY HK-507 230mm
BENDIX H7175 [Hardware Kit] Drum; Rear; 9 1/16 x 1 31/32;
BRAKE DRUM HARDWARE KIT
AUTOSPECIALTY HK-507 [Drum Hardware Kit Rear]
BRAKE HOLD DOWN PARTS KIT
BRAKE BOTTOM CUP
BRAKE TOP CUP
WAGNER F98323 [Top Cup] Rr.
BENDIX H1135-2 w/9 1/16x1 31/32" Brk.
BRAKE PIN OR ANCHOR
BENDIX H5053 [Guide Pin] Front
BRAKE HOLD DOWN SPRING
WAGNER F98324 [Hold-Down Spring] Rr.; Pri.
WAGNER F98324S Carded Substitite for F98324
BRAKE C-WASHER/PIN LINK
BRAKE ADJUSTING SCREW SPRING
WAGNER F98324 [Spring] Rr.; Pri
BENDIX H4818 N/A
Thank you. I have a chance to buy 4000 Wagner brake parts cheep. They all fit 1980 models or older. If I can find some Opel parts in there I am going to get them. Most of the parts are wheel cylinders, brake shoes, and disk pads. Who konws, I might find 50 or 60 opel parts in there
1 - 4 of 4 Posts
