My project car's front suspension was a bit cocked up when I got it. The upper left control arm was bent and one bushing there was coming out. The lower right control arm was also bent.The left upper arm had a collection of different washers, including some SS ones from the hardware store(Not shown in the pic) and one fat washer that measures .36". The right side upper arm just had an assortment of same thickness washers. I don't recall the exact arrangement and it now been months and I forget where everything was, but clearly some monkey business had been going on. Also, the two bolts that hold the left lower control arm's cast iron pivot and the spring saddle to the bottom of the front suspension were both replaced with shiny, lower grade, fine thread bolts. Yup, some sort of monkey business was afoot.
So, tomorrow I start reassembly and I had to get the FSM out. The arrangement of the washers affects the caster of the front suspension. The book says that, from the factory, I should have two .24" spacer washers on the upper control arm bolt, one in the front and one in the rear. I've only got one .36" washer and a bunch of thin and a little bit thicker washers. I don't remember there ever being 2 same size spacer washers, front and rear, on my previous cars' upper a-arms. There was always a thick and a thin one. I would usually put the thick one at the rear position on the a-arm bolt and the thinner one at the front position, in order to have more caster.
I've read the FSM instructions and I pretty much understand what to do. I have basically .48" of space, front and rear combined, to work with and I have one .36" fat washer. So, fat washer at the back, thin washer at the front on one side of the car. On the other side, a thin washer at the front and probably 3 thin washers at the back. Unless, of course, I can find another .36" washer in my hoard or make my own washer out of scrap metal and hole saw.
Okay, fine and dandy. Here's the question that this whole thread is about: What is the "crown" of a washer?
See the pics below from the FSM. Observe what is said in section #7: "Make certain that the crown of the plate washers shows outwards". WTF does that mean? What "crown"? "Shows" outwards? WTF does that mean?
5 of the biggest washers I have are "domed" or caved in, depending on how you want to look at it. I always assumed that "domed" washers on my car were damaged, bent, washers and that they were originally flat. So, now I'm guessing that they were made that way for a reason. I am now assuming that those domed washers are what the FSM says are "plate" washers(see diagram).
Are they calling the "domed" side of these washers the "crown"?
Am I supposed to put the "domed" side of these washers facing OUTwards at each end of the big bolt?
Also, notice on the right side of the diagram that there is a dark area labeled as the "rubber dampening ring". I don't remember every seeing a rubber washer in my front suspensions. Gil had mentioned to me that suspensions that use the oem rubber cartridges need to have the rubber washer to prevent "knock" during hard cornering. Notice that there is only one at the rear, but there isn't one at the front. Gil sent me 3 used rubber ones.
