I found some really good info using the search, but I could not find answers to all my questions. So far I have found this:
PRIMARY(32)-MAIN 135 AIR 165
SECONDARY(36) MAIN 140 AIR 160
and emulsion tube F66
This is for a (likely) tired 73 GT 1.9l
Also, which accellerator pump jet would be correct? (.55?)
I slapped on a used carby originally from a 2L Ford Sierra....
It won't idle unless the idle is set way high (so it is likely off the idle circuit). I haven't pulled the carb apart to see what jets it has, but I will likely just order a rebuild kit and the correct jets (regardless of what is currently in the car).....
Is the above jetting info accurate?
Thanks,
Tim
Thanks,
Tim
