After using last year's Nevada emission's test report to realize my car was running a bit lean I took some steps to enrichen the mixture (i.e. main jets. idle jets). I have a 32/36 DGEV and now I'm not sure if it is too rich (it does run alot better) to pass the test this coming year. I was wondering if when test time rolls around if I just put in a lower numbered primary idle jet (a 55 to say a 50 or 45) might that be a sufficient hedge to lean the mixture out a fair amount......hopefully enough to pass an idle test and a <2000 rpm test??? .
Any suggestions appreciated.
