Though I wrote this primarily for SSD applications, might be worth looking at for twin SDs, if you've exhausted all other jetting options for your engine.Crusher said:Well...I've got the same side-draft carb on my 2L Opel.
I have a larger cam and ported heads with lots of air flow.
I tried the recomended jet sizes for a stock engine of that size but it would run at an idel and not when you open the throttle...too lean, probably because my engine has alot more air-flow than stock.
With an O2 analyzer reading of 1 percent O2 in the exhaust, I finally ended up with 185 jets in an f8 tube...ya, it sounds big, but you can see for your self... My car runs great !
p.s. The DCOE series I've found has a slight flat spot during acceleration...Just the nature of the beast.
I think there's a small misinterpretation of terminology here . . . you CAN, in fact, adjust idle/transition MIXTURE (idle jets and air bleeds) and idle mixture VOLUME by the idle adjustment needle. But you CAN'T adjust transition mixture VOLUME, as it's controlled by a series of fixed orifices just above the throttle plates. The ONLY way to alter transition mixture VOLUME is to enlarge these orifices (holes).Crusher said:You're right, there is no means of adjusting the transition mixture on the DCOE.
I've been sort of leary of drilling on my carb![]()
Kummel - I hope we've added some insight to your carb project.
Steve
