Thanks for the help Keith/Gary.
After looking at the pictures on all sort of different angles,I think i figured it out.
Like i said, i have a 32/36 Web DGV 5A,which is a lot different than the picture. It only has two vacuum connections on it, the brake boost which is shared with a line from the distribuitor(Y connection), and underneath another vacuum that goes also to the distribuitor.
I think what i'm missing is a "Y" connection in the bottom vacuum, so that i can then plug the "PCV" line onto it.
Also, according to the readings, the charcoal canister is not really used with the Weber configuration, is this correct?
I understand the gas tank venting and how to hook that up to the canister middle line, but the other 2 connections from the canister have no place to go.
Gary, does your 38 DGAS use the canister connections?
