I've checked and it does not seem that the secondary of my Weber 32/36 is ever activated. I never see signs of gas entering that barrel. When the rod with the ball joint is manually moved the primary opens and the secondary DOES open later. So the linkages work and are connected and do not bind, it's just that as the linkage is installed in the car, when pushing down the gas pedal there does not seem to be enough movement (or rotation of the rod with ball joint that is perpendicular to the firewall and which is that last rod to the carb.) to activate the secondary barrel.
The firewall grommets are in place. The passenger side one is new. It had to be sanded down a bit to get press fit in.
Here is my main question: Exactly what is adjustable to get the additional movement that is required to open the secondary throttle valve? Are the stock Opel linkages adjustable enough to get the secondary of the Weber to function?
I assume that when that opens, gas should then be pulled into the secondary barrel? I had earlier adjusted the float so that fuel should be properly metered and I have the correct jets installed per previous posts (all these jets).
