Weber snorkel kit
17653 Views 78 Replies 24 Participants Last post by  opelenvy
air filter adapter
Has anyone tested/flowed the TWM remote air filter adapter for our downdraft carbs?
-Travis
61 - 79 of 79 Posts
It is made out of aluminum like the top and bottom. They are cast and this is going to be a piece of tube machined to fit so it will look smoother. I'll post some picitures of it when I get it.
George,
Any chance of getting him to make two while he is at it? I have the same snorkel, as the photo at http://opelgt.com/forums/showpost.php?p=26087&postcount=6 showed, and I can see the value of having a straighter "shot" at the carb. Let me know if he can, and how to make the required arrangements
Selling Points
George,
You may as well post the phone number and reference. I feel this enhancement is about to take off in sells since your make shift part and road test for the adapter solved the intake problem. :cool:
I asked the guy at Jam Engineering if he would do it cheaper if I drummed up some more sales. I told him that I could probably come up with at least half a dozen other buyers. He said that he is doing it by hand one at a time so it wouldn't matter. He said that he should have in done in a couple days, so hopefully mine is already done. Once I get it and approve of the job THEN I will post how to contact him. I don't want to put the wagon before the cart if this thing ends up not fitting or something. I don't see any reason why it wouldn't work, he has the Weber adapter right there to fit it to. I really should have it this week and i will post when I do.
5
I got it.
Got the spacer today. He had to machine a lip to fit the edge snug. This caused interference with the two front allen bolts since the holes are so close to the edge. I used the supplied bolts that came with the kit from Jam. They came with two different sets of bolts because the manual choke carb uses 4mm and the others use 5mm I think. Anyway I belive I am using the ones with the bigger heads, so the smaller head might not even cause this interference. I called John at Jam and he said he would look into this issue with the next ones he makes. The fix would be to use smaller headed allen bolts, or file/grind out a small groove in the spacer. But this is only my problem as John will address this for future orders. The quality of the work is very good and I think a good fix for the problem. I will still need to grind off a small area on the hood to clear where the top of the adapter is rubbing. (shown in an earlier post.) I got mine a couple bucks cheaper since I am the Guinea pig. Future ones will be $25 (plus S/H which he charged me $6).
And now for the pictures.
See less See more
contact
Oops forgot to say, call John at Jam Engineering in Monterey, CA at 1-800-JAM-CORP (1-800-526-2677)
This picture is how I raised up the hold-down for the top portion.
Thats all.
See less See more
James, I have used the Jam Engineering adapter with my 32/36 weber to make a cold air intake, much like the one that opelenvy made. The adapter fits under the GT hood with no problem.
Jim
I was bored last night and removed my snorkle and my cold air intake and hose. I put the old square Weber air filter back on and went for a drive this afternoon. I noticed a big difference after 4500 RPM. I guess the snorkle was a restriction after all. I will probably not buy an adapter ring because I am working on a 45 DCOE SSD to replace the 38, so I'll just leave the air filter on for now. I know it's breathing more hot air, but I do have my header wrapped which helps.
My wife is out of town so I rebuilt the 45 on the kitchen table last night! :p
James
Redesign Suggestion for JAM
George, et al,
Quick fix looks good but, by looking at the middle picture, you could suggest that JAM cast your spacer integral with the bottom adapter and cast the center stud bracket mounting risers taller at the same time. Eliminates pieces, ensures proper fit and simplifies installation.
Kit would then include: bottom adapter with integral lip and taller risers, top snorkel half, center stud snorkel mount bracket, 4 carb adapter mounting screws, 2 center stud bracket mounting screws and 1 acorn snorkel mounting nut.
That said, I'm more than a little surprised that JAM didn't discover this serious air restriction when they originally designed this snorkel. Obviously NEVER tested! :mad:
Otto, this is a univeral application. The height would probably be an issue for other vehicles useing this adapter. If Opel was the only use then it would not justify a separate kit. He told me this was not designed for a high performace application, but more for the functionality of relocating the air intake. I would not recommend people go this route if you are just starting to make a cold air intake. I am just trying to make it work since I've already invested the $$.
If I could do it all over again, I would not have bought that adapter.
My Personal Opinion.
Not again . . .
Says it all now, doesn't it! :(
What's a shame is that it's such a nice looking piece. With the ribs, it matches the valve cover and looks like it was made for the car.
Goes to show you, looks ain't everything! :p
James
James
That's what drew me in. I'm all for things looking nice, but in the end "go" is more important than "show".
Live and learn and teach...so others don't have to make the same mistakes.
Opel Snorkel
The standard Opel set up is VERY hard to beat, especially when fitted with a K & N filter. obviously, Stutgart University had a bit to do with getting the flow inside there correct too! ;)
Stutgart is a long way from Central Texas and I don't think they took into account the sweltering heat we have down here a good part of the year. 120 degrees coming up off the pavement isn't common in Germany. If it was they would have put air conditioning in these cars. :D
They didn't design oil coolers into these cars either, but around here is will more than double the life of your engine. That said, I am not saying there is anything wrong with the stock setup (that was designed for the Solex). I just like to be different. :D I DO think the stock setup can improved upon, though currently I do not think that mine is better. A work in progress...well, that's everything about my car.
JAM Spacer
Hi George,
Got the spacer in the mail today and replaced the the two short bolts with longer ones and noticed a difference when I cranked it up and put it on the road. :D Thanks a Bunch
snorkel
Hi, I have a pic of my setup from jam in the photo gallery right now,fits under hood ok :D
IS that nice!! ??!!
lesliewk - nice work. (worship)
Is it plastic from where the jam peice fits the tubing? hooking up that tube from the valve cover works nicely. Can you give us some details on what you used... ? where you got the parts and such?
thanks!!
your opel is so nice... I love the look of the 4 red tail lights... that's what I'm doing too.
...and the paint. sheesh. jealous.
3
OK, finally got around to doing a little work on the needed areas. Now it will be another couple weeks before I can test it out. :rolleyes:
Oh well here are the pictures. I could probably still open up the intake opening some more, I just ran out of time to work on it.
See less See more
61 - 79 of 79 Posts
