1 - 2 of 2 Posts
· Senior Contributor
i just got a rebuilt weber 32/36 water choke. i ordered the electric choke today along with the carb mounting gasket.i have a few questions right now.. im sure more to come.. i really hope someone can help, cuz i really dont want to mess anything up. well the brackeyt that is on it now will not fit the stock solex throttle ball thingy. so should i cut the solx braket where it will fit the weber and put it on? or try to modify the braket that is on the weber? or is there a bracket you can go out and buy? and my other question is... the 3 screw that hold the whole choke assembly on, should all of them be tightened all the way down or just the bottom one? i'm not talking about the 3 screws that you adjust the choke, but the ones right under those..
im begging please help!!!
Billy, just unbolt the socket assembly from the throttle arm on the Solex and put it on the throttle arm of the Weber. The thermostat housing screws should be tight, but not overly tight, it is only pot metal and can strip out easily. HTH.
1 - 2 of 2 Posts
