221 - 240 of 834 Posts
If you haven’t already replaced your master cylinder and brake booster do it now. There is an access port behind the driver headlight bucket that makes it breeze. Without that access port it takes a lot longer to install.
I got the car as a barn find three years ago. Since then, all new suspension bushings and brakes, from the pedal rubber to the rear drums and everything in between, including new booster & M/C. I know all about that access hole. As I noted, I was admiring the ease with which the headlights open and close -- they did not get that way by themselves! All of it my labor, the exception being new sheet metal in the usual places, and paint.
Can Opeler
Can a moderator make this a sticky? This should be at the top of the general discussions section like every other car forum.
Quite an upgrade, Don.
Are you keeping the passenger side stock?
Cheers,
Ron in Indy
Probably. I have another one but it's kind of a medium brown so it certainly doesn't match. The white one is brighter than the stock interior but it's a much closer match. Besides, I only drive from one seat.
I bought both from a local guy who used to work for Recaro and got them when they closed the facility where he worked. Both are leather and were display models, never installed in a car, so they're brand new. I don't think Recaro ever made a white leather seat for the aftermarket but I can't be sure. The brown one would match the interior in my Manta but I already have a pair of black leather Recaro Style Topline models installed.
I guess I need another Opel with a tan interior. An Ascona wagon would be nice....
I discovered that in the last two weeks, mice have found the Manta. The moth balls had seemed to work. Maybe they are too old. So off to the barn with some traps and peanut butter. Not good.
Can Opeler
My GTs spent several years stored in my barn before I moved to a place with a garage. I’ve had to fight with mice a lot. They did a lot of destruction in my GTs when I didn’t drive for more than a week. I left for a month and came back to find no less than 6 mice living in spare tire area. They ate most of the rear wiring harness and almost caused a fire when I started the car.
Mothballs don’t work it’s a myth. Studies have shown it takes the same amount of naphthalene to make humans avoid somewhere as it does mice. It requires a lot! Mice have been known to incorporate mothballs into their nests in some cases.
Peanut butter and mouse traps have worked for me. I also stuff steel wool in cowl vents.
You guys need to stop by the animal shelter and pick up a six pack of cats. Put them all inside the car. Let them out one week later. No more mice!
Your Opel might smell like cat piss for a while......
:veryhappy
Supposedly mint will keep the mice away. After spending $5k to gut and replace most of the interior on my Subaru (tab mostly picked up by HO insurance) I started placing some mint mice-away thingies in our cars (except the Opel which is already gutted). No more mice problems so far, knock on wood. Not sure if they are working, we have been lucky, or the mice are in someone else's garage eating their cars instead.
I use Shake-Away Mouse Repellent -- a packet up front and a packet in the spare tire area. Have not had rodent issues in any of my cars stored in the detached garage. I do have mice in the garage but they have stayed out of the cars. Available almost everywhere -- Big Box, local hardware, etc.
https://www.shake-away.com/Mouse.php?page=Mouse
I posted on another thread this picture of the heater blower out of my GT after I had acquired the car three years ago -- it had sat in a Pennsylvania garage for almost twenty years. The PO had left a bunch of shop rags inside the car and these eventually found their way into various nooks & crannies, including the blower motor. The good news is that the rags served the rodents' purposes so well they did not need to attack the seats for material.
Vendor
Discussion Starter #233
Interesting list of ingredients. Who knew that mice hated bloody mint! :ugh:
Active ingredients: Dried Blood (5%), Spearmint Oil (1%), Peppermint Oil (1%), and Rosemary Oil (0.5%). Inactive ingredients: Limestone (90%), Hydrogenated Soybean oil (2.5%), and Crystalline Silica (inert) (less than 0.1%).
The mothballs had worked for 6 years. I couldn't sit for long in the car so they were strong. I checked the car just before OctOpelFest and they were not in the car. I knew they were in the barn having seen one run along the rafters. When I did a brake job on my pickup a few weeks ago, I found a grey furry thing in one of the calipers. They just have been good so I've let them hang out.
So, I deploy the traps. Two hours later I go down and one trap is missing. Go get bucket of water. Go down this morning and another trap is missing. Good thing the bucket was still there. I need more efficient traps.
I need to bring one of our borescopes home and see what the heater box looks like. I'll also try some of your suggestions. The barn is too loose to try to keep them out.
Opelnut
mice
got traps Sunday pm and tomcat they look like giant cloths pins with teeth set up 4 in the shop an 8 in the Garage using the tomcat bate in 12 hrs I checked and the 4 in the shop had no mice... woo hoo on the other had the 8 in the garage all had dead mice even the one in the GT. so a bag of the repellent in the car and reset all the traps.... will see I think with the cold this will be a daily chore to trap and repel garage till there gone. will see if the repellent around the perimeter works and slows the ones caught in the traps.
Dont want to poison them as that would affect the ones getting taken care of by the Hawks/ fox's and other good critters
I put in a new ignition switch and "Otto start" relay over the weekend. The hardest part was removing the steering wheel. I managed to bend the arms of the puller the first go at it and then had to grind some bolt heads down to size and use a breaker bar to get it to pop off. Then the small button on the ignition cylinder you have to push in to get the cylinder out of the sleeve wouldn't push in (the key was in the "run" position--I even jiggled it around, used WD-40, and tried to be as gentle as possible). I ended up having to gently tap it in with a small awl before it would release. The switch was black inside and one of the wires was completely burned off--that explains the occasional smoke as it was just resting against the contact and looks like it was arcing to the other contacts. The red wire location on the white connector for the fuse box was also melted a bit. Once I got it all apart, it went back together quickly and easily. Now everything works great!
I also replaced the rubber around the rear quarter pop-out windows and the window grommets.
I’m still trying to work out how to convince the wife that theOpel GT should be in the garage and not her car. Also did a trade for my 96 Ford Explorer for a 07 Pontiac G6. Showed the guy and his kid the GT, they were amazed especially when I flipped the head lights.
I have an Opel??? I'll have to go out in the shop and look! However, the electrical gremlins that grounded me (pun intended) at Bonneville seem to have been wounded (if not vanguished) and my little bike made a (nearly) full pass at El Mirage last weekend. Calculated speed was just over 70 (record is 69) but the clocks did not pickup the number. After discussing that with the rider (I wasn't feeling well and asked a friend to test/ride), we decided that it was probably because he ran out of gas about 100 yards before the time trap! After all the problems we had been having, nobody thought about checking the fuel level! ..:ugh:
As they say, "Next month ..."
I’m still trying to work out how to convince the wife that the Opel GT should be in the garage and not her car. Also did a trade for my 96 Ford Explorer for a 07 Pontiac G6. Showed the guy and his kid the GT, they were amazed especially when I flipped the head lights.
Yea, that should be an easy sale...if you lived in San Diego, rather than Regina. I have been "allowed" to use my wife's side of the garage for up to a few weeks at a time during the winter, IF there was a Chinook blowing (longer during summer months), but Calgary winters got NOTHING on Regina's. :yup:
