I’ve been collecting and prepping parts all week getting ready to send out a batch of parts for fresh gold zinc plating. Some of the stuff I’ve had laying around for years, but never had it plated.
Quite a few components are tolerance-sensitive, so paint or powdercoating won’t work well. For example, my custom outer tie rods I built for racing use on a Manta…the outer ‘cup’ holds a high-misalignment spherical bearing, and is a tight tolerance fit. But I also don’t want it to rust. Zinc plating is a perfect application for this.
The last parts to go out in this batch will be some custom-modified front camshaft covers with a threaded fitting to allow for camshaft endplay adjustment. However I’m still waiting for hardware to come in for those. It should be here tomorrow, so next week I will probably drop these items off for plating.
Here we have some custom caliper brackets for my Wilwood big-brake kits, a couple of Quaife fast-rack input pinions, side and rear cam covers, distributor hold-down brackets, firewall clutch cable bushings for a Manta, a custom water fitting, valve cover tabs from a later steel valve cover, and springs from the headlight assemblies.
You’ll note I have 10 LH/RH 5/8” threaded adjusters to build more adjustable panhard bars. My normal supplier was out of stock so I found an alternative. They’ll work fine but they are only black oxide plated, which generally means they rust in short order. So they’ll get fresh zinc plating.
A few Manta/Ascona hood safety hooks, a couple Manta/Ascona hood latches, two custom Manta outer tie rods, my recently fabricated crankcase breather bracket, and a steering column bearing holder for a racecar.
Close-up on some small parts…hood release cable clips and screws, headlight housing tension springs, and valve cover hold-down tabs as used on the later steel valve covers.
Headlight mounting assemblies…one pair for an Ascona, and a set of 4 for a Manta.
Those eBay chromoly M8 x 1.25 pitch, 12-point nuts with 10 mm heads I recently purchased.
Black oxide keeps them from rusting while on the shelf, but not much more! Yellow zinc looks cool and provides a little more corrosion protection. I like these for mounting carburetors or other places where access is limited for a 13 mm wrench or socket. The 10 mm heads give a ton more access.
