Wow your Gt looks sick! That thing is sweet! How did you do the fender flares?I have those wheels. I painted the lug areas black because Rally Bob is always trying to copy me...... View attachment 453303
Thanks Sam
Hey Rick, not uncommon for me to read about something I am unsure about. Not that I have looked at the oil pump more than a couple of times but I am trying to recall a spring. I recall taking the face plate of the oil pump off maybe two times and two large gears coming out but I do not recall a spring. So wondering if I am missing a part. Oil pressure is close to 4 cruising at 60. Can you give me more information. Thanks, CarlSat down this afternoon with my machinist and Gil on conference call to get all the parts required to rebuild my engine and take it out to 2.0 and some extras. Tear down showed that the engine was bone stock, no major wear to be seen except for oil pump spring had some wear. Excited about moving forward with this car rebuild! When all finished I'm going to own one very cherry GT!
The pressure relief valve inside the pump has a spring in it, intended to keep the valve closed unless pressure exceeds the specified level. When this spring weakens, the valve opens at a lower pressure. I seem to recall Gil advising me to add a shim under the spring. The FSM describes the valve on page 6A-27 of the '73 manual.Hey Rick, not uncommon for me to read about something I am unsure about. Not that I have looked at the oil pump more than a couple of times but I am trying to recall a spring. I recall taking the face plate of the oil pump off maybe two times and two large gears coming out but I do not recall a spring. So wondering if I am missing a part. Oil pressure is close to 4 cruising at 60. Can you give me more information. Thanks, Carl
Early CIH engines have a flat oil pump cover, with the oil pressure relief valve located in the side of the timing cover (below the timing chain tensioner). A 1970 engine would have this style.Hey Rick, not uncommon for me to read about something I am unsure about. Not that I have looked at the oil pump more than a couple of times but I am trying to recall a spring. I recall taking the face plate of the oil pump off maybe two times and two large gears coming out but I do not recall a spring. So wondering if I am missing a part. Oil pressure is close to 4 cruising at 60. Can you give me more information. Thanks, Carl
What is interesting is that the newer engines (I am assuming 1971 and up) seem to have both relief valves, one of which the factory rendered inoperative. Quoting from page 6A-5 of the 1973 FSM (my emphasis added):Early CIH engines have a flat oil pump cover, with the oil pressure relief valve located in the side of the timing cover (below the timing chain tensioner). A 1970 engine would have this style.
Later CIH engines have an oil pump cover with integral oil pressure relief valve, and that is where the spring is located which was mentioned previously.
Thanks Bob. Just as a note, my engine is a rebuild from OGTS purchased in 1998/9 and frankly not sure what year it is. I am thinking perhaps a 1975 which is just an uneducated guess, perhaps something that Gil mentioned at the time, and is a 2.0. I know that Gil said that everything would bolt up just like the original 1.9. This engine has GM stamped on the driver's side. The only thing that turned not to be a direct bolt on was the fan which hit the crank as it had a longer bolt head, which had to be replaced with the shorter head unit and the oil pump cover did not require a gasket but a thin layer of sealer instead.Early CIH engines have a flat oil pump cover, with the oil pressure relief valve located in the side of the timing cover (below the timing chain tensioner). A 1970 engine would have this style.
We will need pics of when the engine gets painted.Well update, new heater core is in and blower lubed. Headlights rewired, oh and cleaned out about another 20 pounds of soda from inside the car, and headlight buckets where whoever blasted the car did a piss poor job of cleaning. Everywhere soda was scraped and removed, rust was under, so glad that was caught. Calling Isky about my cam, they've had it for three weeks now. Engine block gets powdercoated tomorrow.
I will be looking at different colors tomorrow, when powder coating cast iron, colors shift. I'm hoping to have the block look like regular aluminum and the head billet.We will need pics of when the engine gets painted.![]()
Awesome!I will be looking at different colors tomorrow, when powder coating cast iron, colors shift. I'm hoping to have the block look like regular aluminum and the head billet.
< snip > Crank is getting ground and cam off to Isky. Progress! Hoping to have it all back together by 1st of April.
Happy to hear that Ed Iskenderian Racing Cams will regrind Opel camshafts.Cam made it to Isky!
Hydraulic cam and lifters are matched. But, understand Isky is slower than slow and they will not return phone calls, even when I was told they would. At least they do Opel cams and have had mine for over a month.Happy to hear that Ed Iskenderian Racing Cams will regrind Opel camshafts.
Is your cam hydraulic or solid lifters? If hydraulic, what lifters are you using?
