Clutch and rear end question
My car is in the air on jackstands while the new engine is being broken in. I noticed that while it is in neutral and the car is running that the rear wheels spin. I can stop either of them with my foot very easily but the other one than the one I stop still spins. When I put in the clutch they will stop.
I thought my clutch was out of adjustment and tried several adjustments there on the bell housing but the wheels still spin. Is this normal? I realize that most people don’t run the car with it in the air so this may be normal I don’t know so I am hoping someone who is mechanically inclined might know if this is normal.
Is my clutch maladjusted? I have the approximate 4.29 inches that the book calls for of cable there from the bracket that holds the clutch cable to the thing that comes out of the transmission where the cable hooks I have approximately ly1/2 to ¾ inch of play in the petal
Note my flywheel has been lightened to about 13 pounds from the stock 23lbs in case this makes a difference.
Also when the Manta Rally is running since the drivers side wheel will turn on its own while I am holding the passenger side still does this mean that this is a posi rear end?
