1 - 3 of 3 Posts
Pathologic Opeler
right now..i have oil leaks all over..i am afraid to drive till I top off my fluids...
is this where the oil goes?
how much to put in?
what size tool?
Pathologic Opeler
17mm hex for oil ?
i think it is a 17mm..couldnt find the right tool ... but I found something close enough
Next time you are at Autozone, you might check for a set of hex key sockets for tranny work- they don't cost much.
A good tip- if you are going to change differential or gearbox oil, take out the fill plug first before you remove the drain plug. You've got a problem if you have drained already and can't get the fill plug out.
1 - 3 of 3 Posts
