1 - 4 of 4 Posts
Pathologic Opeler
I get my 69 gt next week,but the current 1.9 engine is not the original,How do I determine if the engine is the higher compression or lower compression version.I asssume the 9/1 compression engine has more horsepower..and would be more
desireable.
1968-1970 have the 9:1 flat top motors and 71 and newer have dished pistons (7.6:1) if its not the origional you can check the head if it has not been replaced. remove the valve cover and on the drivers side of the car there is a 2 diget number near the gasket surface of the valve cover. these 2 digits are the year the head were made. OR remove the starter and there is a serial number behind the starter. the last 2 digits tell the year of the motor. another i have heard but not tried is to take out #1 plug and bring the motor to TDC and shine a pen light into the cylinder and check for flat tops or dished pistons. IDK if the higher compression motor has more horse but like you i would assume it does. good luck with you new ride!!!!!!!
Pathologic Opeler
compression
If the car requires premium gas..doesn't that mean it is the high
compression version?Does the high compression engine Knock
or run porely on low octane?
1 - 4 of 4 Posts
