Ok, here is the info I have for a 1975 clutch fan assembly. Eventually Opel used a fan clutch like the Hayden 2558, that screws onto the water pump pulley. Unfortunately, my computer that has the info for that setup isn't accessible until September but I can provide everything needed for the 1975 setup, which is what I have in my garage waiting to be used in my 2.4L build.
This is what the whole assembly looks like once done...
The water pump is a GMB 155-2010 and is a replacement part for GM part number 80 090 517, which is the part number on the NOS water pump I have. You can find the GMB water pump online through various sources. It comes with a gasket.
The original fan clutch was GM p/n 08960124 or Opel p/n 1340151. I have a Beck Arnley viscous fan clutch as well, which is p/n 130-0060 but this is also a NOS part that I don't think Beck Arnley provides anymore. This was a somewhat common fan clutch however and was used on the
Volvo P1800,
MG Midget 1500 and Triumph Spitfire, and the
Ford Capri. So, there are a lot of part numbers connected to this viscous fan clutch and that also makes sense. Car manufacturers prefer to use a part already made whenever possible. This is a somewhat unique design actually for a fan clutch, most rely on a threaded attachment or bolt to the water pump in a few spots. I have an alternate GM p/n - 90091367 - for this fan clutch and a Ford p/n too - 75EB-8A-616AA - which is for the Ford Capri. The Ford part number is straight from my Beck Arnley clutch. This will likely be the most expensive individual part of the assembly, between $100 and $200.
The fan itself could be tricky to find if the sources I have no longer have any in stock. The GM p/n is 08960064 and the Opel p/n is 1340069. Opel GT Source used to have a 7 blade fan (p/n 11034) but they don't show it online. I can't even track down the original part numbers anymore online and I used to find two places that had the 5 blade fan listed. The only lead I have on this fan right now is on eBay in Germany...
Original Opel Manta A B Rekord E Fan Impeller 08960064 | eBay
There might be a Volvo fan that works however. When looking up info on the fan clutch, the Volvo fan showed up as a related part on eBay and it looks pretty similar.
vintage volvo b20 fan blade p1800 1800e 1800es 140 164 oem clutch fan 679276 | eBay. The Volvo part number is 679276.
As for the hardware to finish this off, I bought what I needed from McMaster Carr. Socket head bolts / screws seem to be used a lot on CIH engines, so I kept up with that. For the four smaller bolts and nuts to attach the clutch to the fan, I used
p/n 91270A290 for the non-marring locknuts with spring-lock washers and
p/n 92235A242 for the socket head bolt. For the center bolt, it needs to be a left-hand thread M10x1.5 and somewhere around 15 to 20 mm long. I used
p/n 90605A302 and used
p/n 91116A390 as a suitable washer to go with it.
The fan will be the limiting factor for anyone wanting to do this and it could take some hunting for people to find one. Eventually Opel went with a different and more typical setup, where the clutch screws onto the water pump pulley. That newer design does stick out a little more however and I don't know if it will still fit in a GT or would it hit the radiator? I know the ‘75 design that I’m covering here will fit, it’s the most compact option for a clutch fan. I also like oddball, year-specific things in cars so I wanted to use the setup from the 1975 Manta. Based on the info I have shared in this post, someone could get all of these parts for $282 plus shipping and taxes but that only works for the first person to buy the fan from Germany.
If someone wants to do this and asks nicely, I can provide the washer and 4 smaller bolts and nuts, since I have spares. They would only need to buy the center bolt.
