...so long as you power the coil with the stock resistor wire, but you MUST power the Pertronix with a bypass, non-resistor wire, full voltage. And I moved this to the "Ignition" Forum, where there are LOTS of threads on the topic (yea, yea, "use the search" lecture....)greensmurf20 said:you can use the stock coil with the Pertronix unit. a flamethrower would would probably enhance the performance, but stock works fine.
Come on, guys, it's REALLY quite simple!kwilford said:...so long as you power the coil with the stock resistor wire, but you MUST power the Pertronix with a bypass, non-resistor wire, full voltage. And I moved this to the "Ignition" Forum, where there are LOTS of threads on the topic (yea, yea, "use the search" lecture....)
