Jim;
Yes, they still have the bold lettering on the sidewall, as for flexy, I don't know. I'm not running sway bars, but, I can take the same roads in my GT, that I do in my Sportwagon with front and rear bars. Holds just as good, if not better. But, that could be due to lower center-of-gravity. As for wet traction, I find that unless you run around with the GT's tank full, the rear tires will break loose, not easily mind you, as there is no weight in the back of a GT. They are nose heavy. But, wet traction I have found to be very good, and they channel water well, for straight driving. As the T/A's I have found are generally cheaper than anything else in the Atlanta area, I got my last set at Sam's Club, even got their $5 per tire mounting. Just about every other brand I have found to be higher.
Gene
