· Member
My wipers won't work. I cheked the fuse, it's good, Back up light works, horn does not. Pulled wiper moter and hooked it up hot and it works. I've read the thread on wiper gremlins and was wondering if any one has by-passed the foot pump. Do you think that will work?
Thanks
· 4ZUA787
when this happend to me i had already disconnected the foot switch wires and taped each one off sepratley, and my wipers worked fine then one day they stoped working so i was like sh$t and i looked for every thing i thought it could be, i turned out that it was the fuse, all my fuses are those ceramic type ones not the glass, although one had been replaced with a small glass type one, this happend to be the fuse that ran the wiper motor when i took a quick glance it looked like the fuse was ok but i finally was like cant hurt to try the fuse so i pull it out and the fuse is blown so i go grab anthor fuse and stick it in and boom the wipers work perfect. just one thing to check.
· Member
Thanks PVCAR, My fuses are not the glass ones and I replaced just to be sure. When you removed the foot pump did you put the lines together?
· Member
I would check the wiring connections under the dash. The plugs are notorious for making poor conections. I just recently eliminated my foot pedal. I installed to momentary switches on the console just in front of the shifter. The one on the right operates the wipers as long as it his held down, and the the one on the left operates the washer pump. The switches are black and nearly flush with the surface of the console. Much easier to reach than the floor pedal.
