Ken, as far as the solenoid connections, one is used to engage the solenoid and start the engine, the other is to apply 12 volts to the coil during starting. When the ignition key is released from the start position, the resistor wire from the fuse panel supplys power to the coil. A little insight on coils, from the time the manufacturers went to 12 volt batteries, the ignition coils have always been 6 volt. Ford uses an internal resistor in the coil, GM and others use a "ballast resistor" to drop the voltage to 12 volts during normal engine running. If you feel you don't need 12 volts to the coil during starting, you can leave the coil wire disconntected and tape the end of it. HTH.
Ron
Ron
