Another headlight question...
1 reading
2.1K views 4 replies 4 participants last post by  jlthunder
#1 ·
Just redid headlight wiring (still have the housings out) on a GT I've only had a month or so, and just beginning to go thru it. Just wired up a headlight to test it...pushed the lever forward, and no headlight. However by turning on the parking light switch the headlight comes on, and from there the dim/bright switch works along with the blue dash indicator. Could a bad headlight relay cause this or maybe the wiring is jazzed up further into the fuse block? Haven't got that far yet. Mechanisams seem to be fine. and am hoping they don't need to come out. Any help will be appreciated :) Gordy
#3 ·
Sounds like a PO (Previous Owner) re-wired the headlights to power the main headlight relay from the parking light switch. Pretty common, when the micro-switches fail, and a PO doesn't take the trouble to fix them properly. Have a look at the wiring around the silver relay cannisters under the dash, and I suspect that you will see some non-OEM additions. Does the white dash indicator come on when the headlight buckets are partway up or down? If so, then the other micro-switches are still functional.
#4 ·
Destec Engineering Wiring Diagram
I bought a large laminated Opel GT wiring diagram from Destec Engineering on E-Bay, and hopefully that will help me figure out the headlight problem. I have tried to work off of the diagrams in the Opel manuals, and my old eyes can't handle that. This Destec one is great..all one piece, about 2 feet long, laminated, color coded wires, with tips on how to remedy some common GT wiring problems. I would reccommend every Opeler should have one. Gordy
#5 ·
This may be a dumb question, but was the key turned on? If not, your headlights won't work. Sorry, but I always look at the simple solutions first.
