My gt won't shift into reverse. Could the ice storm we are having have frozen the linkage?
Yeah right http://www.opelgt.com/forums/general-discussions/45218-cold-gt-problem.html#post491258I'll replace the gear oil with a good synthetic
Had an old Toyota that I broke reverse in. Spouse and I drove it for almost 2 years without it. Just had to think when parking, pull thru, park on uphill, pull up roll back to park etc etc. Only time it was hard was in snow and drunk driving.Always park so that you can drive out in a forward going gear.
U:ugh::arg:One other thought..
Does your shifter tilt to one side.. (I.E. Manta tranny in a GT)
If so with bad, worn and squissy mounts, it could make getting the shifter over to the R hard. So if the GT was a on a banked area the tranny would shift one way and it works. Banked the other way, it binds and won't.
I seriously doubt it was ice. Unless you drove up onto some snow bank or something. Trannys get hot and thus should melt off any ice.
The reverse lockout 1b and 2 can't move lever into R:sigh:Maybe not.. Tranny shop time..
If its an in and out thing.. have to nail it down first.
1) Does it not go down into R
1B) Is there resistance to the pull knob on the shifter.?
or
2) Does it not get far enough to the left to get in the slot to go down at all ?
or
3) Does it go into gear, but won't move
#1 - Linkage adjustment on transmission, ( there is a nut that adjusts the shaft that slides left to right), Clutch cable adjustment (Pull it out a ring or two and see if that helps), or Clutch adjustment at Bell housing
#1B - Broken shifter
#2 - Tranny mounts, and possibly have a Manta transmission so shifter is not getting far enough to the left.
#3 - Clutch or Yea.. time for Transmission shop..
Bet its #1 - #2 and in that case its something you can fix in the garage.
Linkage problem for sure.. OR the Manta tranny in a GT issue..The reverse lockout 1b and 2 can't move lever into R:sigh:
The shifter is straight.Linkage problem for sure.. OR the Manta tranny in a GT issue..
In neutral is the shifter straight up and down or pointing to the passenger side by about 15 degrees ?
You probably have a Manta (Or Kadett) transmission and need a new tranny mount.
Ask around someone may have the spare yoke for the transmission so you can take the tranny to a shop and have them replace the yoke. The one for the GT is tilted so the shifter comes up straight.
The shifter is straight up in NLinkage problem for sure.. OR the Manta tranny in a GT issue..
Then go for the low hanging fruit first..The shifter is straight up in N
What would keep the lever from raising up?Then go for the low hanging fruit first..
Pull out the clutch cable 2 rings and see if that helps.
If not.. then get under it and check the linkage and make sure nothings bent or broken.
If not that, get under the car and check the cable adjustment at the arm.
If thats all good.. adjust the shifter linkage that slides left and right.. doesnt take much adjustment there.
The black ring..? The cable inside broke OR the spring holding it down has gone "Boing"What would keep the lever from raising up?
Sounds like you MAY need a new shifter.
They don't list everything they have in the catalog. Call?In OGTS? I couldn't find it in catalog![]()
Car runs great and shifts in 1-4 gear. The ring won't lift up. I took the boot off but i can't.see why the ring won't lift up.:feedback:Odd...
I just started my GT. It's about 20 degrees out.
It didn't want to go into gear.
If it was idling and I let out the clutch it died.
I think George unleashed a virus or a voodoo spell or something.
